Fuel filter, hand pump location C5
Slinnian
Unread post by Slinnian »
I am trying to drain my fuel filter of water, etc. but can't seem to find the hand pump anywhere!! I have a citroen c5 2.0hdi 2001. It has no horse power when starting off although cruises ok when started, so I suspect the filter may be dirty or need purged. Any suggestions where the hand pump maybe? I have the Haynes book and have followed its recommendations but nothing!! :(
oneday
Re: Fuel filter, hand pump location C5
Unread post by oneday »
no hand pump on a c5 2.0 hdi they are self priming so no need for one. is the power loss upto 1500 rpm
306 1.4 LX MERIDIAN
Slinnian
Hi oneday, thanks. Not sure, about the rpm as my rev counter isn't working!! I have no real acceleration when overtaking or starting off, but it cruises ok at 50, 60, 70mph for example? I'm only assuming it could be the fuel filter as I had a similar problem before and it was water in the filter!
oneday
is your throttle lower than the brake peddle
306 1.4 LX MERIDIAN
Slinnian
It is actually!
oneday
remove the slack from the cable you will notice the change strait away.
remove air box and inlet hose you will see the throttle position sensor below the engine fuse box pull clip from cable pull slack untill the throttle is level with brake peddle replace clip refit air box and test drive let us know the results it only a 10 minute job
306 1.4 LX MERIDIAN
Slinnian
Thanks oneday will have a good and let you know :)
oneday
your still online you could have done it by now lol
306 1.4 LX MERIDIAN
Slinnian
Reading your instructions and trying to give the kids lunch lol!
oneday
sell the kids use the money for fuel lol
306 1.4 LX MERIDIAN
Slinnian
I've considered it lol! Car sorted, now works a treat!! Thanks so much, saved me a trip down money lane lol!!
oneday
happy it worked for you please forward all saved money to me but not the kids lol hope this has sorted your power problem
306 1.4 LX MERIDIAN
Slinnian
Sorry they all come as one package lol. Thanks once again :)
