Problem with the climate control, driver's side hot, t'other cold. Had same problem with old 53 plate C5; changed the module by the clutch, easy job. However, I can't locate the module on the newer 57 model, I've looked down by the clutch under the centre console but can't find it. Is the module the same, or in a different place?
Hope you can help,
Thanks in anticipation
Steve
