Xantia 1.8 16v 'Missing' Problem sorted, Thanks
Hi
The car is missing during normal running and doesn't run that well when revved up high. This fault cannot be atributed to one cylinder alone.
Between a couple of guys and I we have tried to disconnect all injectors, unblocked a breather pipe or two, I even had a garage look at it for a few hours - all to no avail. The garage did not charge me, well a pint or two is owed.
We even tried changing the coil pack, checked exhaust seal in front of the labda sensor, listened for leaks in the air intake etc etc etc
The ECU light is not coming on, so what could the problem be?
Where is the MAP sensor, and how would you remove and inspect and test this?
How do you remove the lamda sensor in the front pipe? There seems to be a 21mm hexagon head here but I don't know whether or not I am supposed to pull the sensor out or unscrew it.
Please help - deparate!!!
Hugo
Hugo
I think you should leave the Lambda sonde where it is.
The indications are intermitting misfires on random cylinders any speed.
This can not be caused by failing sensors controlling the mixture - as you would then have constant indications of lean or rich running.
I'd look for either water in the fuel - or an intermittent working ignition TDC sensor or it's cabling/connector.
Hi Anders
Since my last post yesterday, I think I have found the TDC Sensor, The engine stopped when I disconnected it.
There are 3 spades on the connecter on the end of the wire coming out from the flywheel vacinity. A reading across the centre and one of the side spades came up at around 99 to 102 ohms, so it looks like this is not where the problem is.
In addition, the fact that the engine stopped when it was disconnected demonstrated that it was doing something at least.
Also, I forgot to mention that in addition to the missing, the car is also backfiring especially when starting up.
In addition, disconnecting the Lamda Sensor does nothing to affect its running.
Any further guidence would be much appreciated.
Many thanks
Hugo
Many thanks
Hugo
hugo -
The backfiring may indicate an ignition problem - then likely to be an unstable TDC ignition sensor. They are known to fail even if they check out ok with an ohm meter.
Try this site for further info on components involved with the engine management system :
http://www.tramontana.co.hu/citroen/
If I were you I would get the car down the citroen garage for diagnostic before your cat dies on you. They dont like it when the engines misfires it cause them overheat. £200 for a cat is not cheap whereas diagnostic at cit specialist would be much much cheaper than that. Don't forgot to change your spark plugs as well when the engine is running okay again. MAP sensor my main suspect thats if it has one.
Try and avoid disconnecting Engine management components as a form of testing,. This generates a fault code in the ECU and can contribute to poor engine performance.
Have you carried out a compression test? The back fire, mis fire could all be attibuted to either sticky valves, poor compression, etc.
Would suggest compression and /or cylinder leakage test.
Thanks for your input guys.
Citman
I would very much like to get the car to the Citroen Specialist for a diagnostic check but it is neither insured nor taxed. Hence I am looking at £100 before it even leaves my drive! I was going to use it myself but have now got another car.
Does anyone know of a website that can direct me through a self diagnostic test? I know vauxalls can be tested this way and fault codes read by counting flashes on the ECU light etc.
Jaxs
Thanks for your ideas, however, the engine is a low mileage C18000 replacement, I suspect that these faults are unlikely.
In addition it was running fine then suddenly deteriorated instantly, rather than over time.
Thanks again
Hugo
Citman
Jaxs
Thanks again
Hugo
