anti polution fault/ cruise control
bill196510
why does anti pollution fault come on when cruise is used
C5 2.2 hdi 2003, called it oliver reed, drinks like him
Good on fuel now, lol.
Ben82
- x 7
Re: anti polution fault/ cruise control
Always/Sometimes/Just Once?
Straight away/After x miles from turning the Cruise Control on?
Does turning it off clear it?
Is the Check Engine Light on?
Best to get the codes read too.
If it happens always, straight away after turning the cruise control on, then it could just be a short somewhere, or it could just be a co-incidence and you catalytic converter is knackered. Won't know without far more information/diagnosis
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
bill196510
usually after a few mins but today ten seconds. read codes. look at my first post . puts engine light on and triangle esp asr. sometimes comes on without cruise. but cruise seems to make it happen. mapping out dpf and egr next week. see what happens then lol
Ben82
- x 7
The codes start with a P eg. P0420
Anti Pollution Fault covers many codes, so needs to be hooked up to an OBDII Reader/Lexia to get them. ESP/ASR would be unrelated to Anti Pollution. Does it also come up with the "ESP/ASR Not functioning" message at the same time?
Given the limited information, I think it could potentially be an electrical load issue, how about a test, turn as many things on in the car as possible (without cruise control), e.g. rear heater, AC, radio, lights (interior and exterior), fogs, put something in the 12V socket, turn on the cig lighter etc as much as possible at the same time.
bill196510
Just done the overload test, nothing happened,been on obd11, poo24, p0026, still none the wiser lol.yes esp asr and antipollution fault,at same time
Turning cruise off does nothing, I use obd11, reset, and its ok,
Shows no codes, now, even after limp mode
Look at my posts only got a few lol
Makes me wonder if its worth bothering with,
Might be vw time agian, i like this car though,
Combined with joke econemy, its crap.
Good car this, not !!!
Stands me at £1200
£400 tyres on few weeks ago
Stands me at £1200
mooseshaver
I had a 2.2 mk1 that did this. Anti pollution fault can be anything, and the ESP/ASR fault is because the car has turned off because of the first fault.
In my case it turned out to be a electro valve that was faulty. It caused the boost pressure to be too high somewhere. Usually when on cruise at 60 and I hit a slight hill. Got worse over time. The garage that fixed it used a pressure tester to find the fault. The dealer that looked at it first was convinced it was the turbo so watch out.
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
bill196510
what pressure should they be,i got vaccum tester
mooseshaver
Sorry I know nothing. It was a Citroen specialist in Carlisle that sorted it
Gone cars.
Gone cars.
bill196510
mooseshaver wrote:I had a 2.2 mk1 that did this. Anti pollution fault can be anything, and the ESP/ASR fault is because the car has turned off because of the first fault.
switched pipes and electrical connectors with egr electro valve,cos its not used any more,and plugged egr pipe
sorted,thrashed it up and down duel carrigeway,used cruise trying to get it to antipollute,lol.brakes more powerfull,goes like saluki on steroids,lol.
still did 34.9 mpg,usually 31mpg using a feather on the throttle
mooseshaver
Really? Hoorah!
Driving 10miles to work and doing short journeys for callouts my mk1 2.2 did 34.4 mpg.
When I first got it I saw 49.something after a motorway trip. It never hit that again.
Gone cars.
Gone cars.
bill196510
Just did 38.4 from alfreton to chesterfield, not an economical journey, usually 24/27, strange that turbo pipe affects mpg
Monkeyfeet
wow 34.4, that's pretty bad. I'm worried 'cos at the mo' mine's struggling to hit 40. Over the last few years it's been consistently around 43 but high forties on a run
I think the best was 50.5 back from Luton to Durham and back - yes feather throttle too and don't brake for roundabouts (just coast for as long as poss). I won't go below 56mph on m'ways and dc's though. Cruise on at about 65ish.
I want to do a vacuum check in the future too - get the alarms if I floor it too much as well.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
bill196510
Its more than doubled my round town mpg, 0.9 miles uphill from cold, was 9.4 now 21.3, cant wait to see motorway mpg
