C1 dificult gear change
x 94
Unread post by citronut »
a friend of my daughters has a 56 plate C1 manual petrol 30ish K on the clock,
dont know exactly what spec yet
she went to work fine no prob's, then on setting off to take boss's kids to school it firstly jammed in gear, then once cleared was almost impossible to select gears,
later it drove fine again is this gear selector cables/clutch or cable or a gear box issue
Regards, malcolm.
daviemck2006
x 496
Re: C1 dificult gear change
Unread post by daviemck2006 »
I'm on the c1oc, the earlier c1 and 107 and aygos have known clutch problems. The later ones post 09, the facelift ones have uprated clutches, 190mm valeo rather than 180mm which are much improved and are a direct replacement for the smaller one. It is highly unlikely to be the gearbox itself, but I think the cables are adjustable. See here. There is a thread dedicated to clutch issues, they are very intolerant of poor driving styles, such as holding the car on the clutch at junctions etc. Clutch issues are the biggest issues on the citybug trio.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
oneday
Unread post by oneday »
our office manager at work had this with her aygo i read up about it and thought it would be the clutch loads of reports of clutch going at around 28k had a closer look changed the oil to try that its bee fine now for about 7k changes gear as it should got to be worth a try first
306 1.4 LX MERIDIAN
Lighty
x 35
Unread post by Lighty »
The Clutch pressure plat is held to the outer casing with 3 steel straps, one of them snaps or the rivet fails, this causes the clutch to not clear properly, so the gears become hard to select, if not impossible. We fit Exceedy clutches from GSF, they seem very good compared to other makes, and we haven't had a faulty one yet.
Probably replaced about 20 with this problem.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 94
i have it coming in on Friday to replace the gear oil,
but its starting to sound like the clutch might be failing
Regards, malcolm.
spider
x 77
Unread post by spider »
I've heard the clutches are a bit weak too, I'm pretty sure the very newer models have the larger one anyway (before it was Diesel only I think?) and its a straight swap.
I seem to think its a Yaris or other Toyota small transmission so it will be cable change, probably you'll find there's no adjustment on it but to be fair that transmission should be quite strong generally anyway.
The only other things I know about them is the water pumps are a bit weak (although very easy to change) and I seem to remember someone saying something about the tappets, possibly they did not have any shims or something ie you had to replace the buckets (!) but I'm not sure, guess if its running nice and not making noises its OK. :D
Andy.
colin machin
Unread post by colin machin »
is the clutch cable adjustable on the 2009 model c1 the foot peddle is almost out be for it bites
C5 2007 HDI
colin machin
hi sorry about above post i got off my back side and checked my self ,yes there is adjustment on the clutch cable its at the gear box end of the cable the cable has a thread on and passes through a large plastic nut thats adjusted by hand ,no spanners needed .
C5 2007 HDI
x 8365
colin machin wrote:hi sorry about above post i got off my back side and checked my self ,yes there is adjustment on the clutch cable its at the gear box end of the cable the cable has a thread on and passes through a large plastic nut thats adjusted by hand ,no spanners needed .
Indeed, I was going to say until I read you'd already seen it!
Zelandeth
x 1593
Unread post by Zelandeth »
Seems that these came out of the factory on a regular basis with the clutch very poorly adjusted. Every 107/C1/Aygo I've driven (mine, three pool car C1s at work, and two hire cars) has had the cable way too tight resulting in a pedal that has to be almost right out before you get any bite from the clutch. Reckon this may well be why my ones clutch release bearing disintegrated after 50 odd K miles - clutch itself was still OK, just the release bearing went.
Was told by Peugeot when I mentioned it at several services and they kept telling me it was non-adjustable! Only found the adjuster completely by accident one day.
Reckon I must have adjusted about an inch of tension out of the cable before I had the correct amount of free play...
Current fleet:
x 8365
Mine is fine Zel :D
daviemck2006
x 496
I adjusted the last one, haven't touched this one yet, but am going to, the bite is quite high. I've not looked at it because my right hand is knackered and can't grip with it.
Peugeot boxer 2016
In the family
Zelandeth
x 1593
CitroJim wrote:Mine is fine Zel :D
Well they wouldn't have dared give you one set up poorly would they, Jim? They have more sense than that!
Current fleet:
daviemck2006
x 496
Re: RE: Re: C1 dificult gear change
Maybe when he signed the order form citrojim, citroen towers, citroen square, citroenville, C17 80EN gave the game away that it had to be perfect [emoji13]
Peugeot boxer 2016
In the family
x 8365
daviemck2006 wrote: Well they wouldn't have dared give you one set up poorly would they, Jim? They have more sense than that!
Maybe when he signed the order form citrojim, citroen towers, citroen square, citroenville, C17 80EN gave the game away that it had to be perfect [emoji13][/quote]
:rofl2:
