Hi guys,
My Xantia's headlights are getting a bit misty. I've heard the glass can be opened up by removing the clips. I have done so but the glass remains stuck fast to the headlights. Tried using a blade but the glass sounds like its breaking off. Do I have to use force to open up the glass or is there something else I need to do? I guess I have to remove the grill too. Any advice?
How to take out Xantia headlight glass?
bxbodger
I have not done this on a xantia but I once had to do it on a Skoda Favorit, and on this once the clips were off the glass was still held in by bathroom type silicone sealant to keep out the moisture, and you will have to clean it off and then reseal the new glass.
It will be a lot easier to do with the lamp out as the lens will most likely break.
Are they misty as a result of moisture? If so you may only need to reseal them.
Guru Meditation
Hmmm...I'd like to know the answer to this question-the headlights on my ZX are ****. They are the twin H4 bulbs. They are broken on their mounts and pretty dim so I'd like to clean inside. Why is it every car I own has broken headlights??? How the hell do they get broken-both side are held in by cable ties:-(
I heard the Xantia has a headlight problem in that they don't get the full 12v feed or summat due to poor wiring design-is the same true of the ZX?
NiSk
John!
You can't get at all the clips without at least removing the front bumper panel and preferably the whole headlight assy. too. That's probably why you're having trouble getting the glass off. Then there is a rubber/plasticy seal between the glass and reflector, but it should come off without too much resistance. Try easing with a wide bladet tool of some kind.
//NiSk
//NiSk
JohnCKL
Nisk, thanks for your advice. I didn't remove anything prior to removing the 3 top clips, no wonder it didn't come off. I thought it was that easy. Yup, bxbodger, I will reseal the glass with silicone once I'm through cleaning it. Don't know why it's kinda misty, maybe they were not well sealed. Looking forward to having brighter lights, thanks guys.
wrinklet1
BonceChops
JohnCKL
BonceChops
JohnCKL
JohnCKL
Did it at last. Cleaned the glass and also managed to lightly wipe the silver surface without it coming off. The silver surface scratches very easily and when I used the wiper cleaner to clean it, it somehow tarnished the silver a bit. Thereafter I just use a damp clean soft cloth without any detergent to clean the reflectors. Cleaned the glass with the wiper cleaner and dried it with hair dryer. Put some silicone sealant on the tacky seal and clipped it back. Now both headlights look crystal clear and brand new!
BonceChops
JohnCKL
Can't really tell. Looks slightly brighter but no way to measure it. Should be brighter, after all, the haze on the glass and relectors have been removed. Well, the looks are there now, crystal clear and brand new looking, with a few scratches on the silver. Only the stone chipped outer surface of the glass gave it away. Makes you wonder where the haze inside comes from.
BonceChops
