removing battery for external charge
NornIron
Bought a Citroen Xsara Picasso a few weeks ago, it was sitting at the car dealers for a while and then with me for over a week. Went to start it and no luck. Did a jump start and it was fine, only got driving it for about 15 mins though.
Had to leave the car unfortunately for another 6 days before going near it and guess what? Dead again! Tried jump starting again but nothing this time. Have removed the battery to do a charge overnight to see what happens.
Question on battery - I removed the + and - terminals and the retaining bar. I then went to pull the battery out and discovered there was a tube going into the side of the battery. This went down into the base of the car. What is this?? I have accidently broken this whilst removing the battery.
2003 Citroen Xsara Picassco 1.8i Exclusive
oneday
Re: removing battery for external charge
sounds like its the battery vent tube so not realy an issue
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
NornIron
oneday
invisible pictures
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
NornIron
What invisible pictures? I'm blaming photobucket, was getting messed about on the beta version.
Mandrake
- x 695
Pictures are ok for me.
Probably just a pressure relief drain pipe. These days car batteries are fully sealed to avoid water loss, however there still has to be a pressure relief valve in case the battery is severely overcharged. The pipe will just direct the overflowing battery acid onto the ground instead of into your engine compartment...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
oneday
now there are pictures yes agree with you simon nothing to worry about
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Mandrake
- x 695
If it was mine I would probably glue the plastic angle joint back on with a fillet of some 2 part epoxy glue like 5 minute araldite. Not sure if it would be successful but I'd give it a try.
Simon
1978 CX 2400
1978 CX 2400
NornIron
Thanks for all those repIies. I have charged the bettery overnight and put it back in and nothing.
Looks like I need a new battery then? Any other thoughts?
- x 5672
Can you check the battery voltage?
Although it does look like a possible broken lead or connection if there is no response whatsoever with a freshly charged battery in place.
You didn't by any chance connect the booster the wrong way round, if so it could have popped a fusible link. Not sure if there is one on your model but worth a look before you lash out for a new battery.
NornIron
I haven't touched the booster, not even sure where that is!
- x 3296
The problem may be due to the battery going flat and then being left like that for too long. A battery with a full charge can be left on the shelf for months (depending on the battery, 6 months can be achieved), but a battery that does not have a full charge can fail within a fortnight. The problem is, in effect, due to the strength of the battery acid; when fully charged the acid is weak as water, but as the charge drops so the strength of the acid increases. Some batteries can be recovered by a series of discharge cycles, others can't.
The last company I worked for were in the IT industry, repairing equipment. One thing clients needed were UPSs (Un-interuptable Power Supplies). These used Lead/Acid batteries. Each one had a date stamp on their box. Exery 3 months they were put on a 24 hour charge, then stamped with the date of that charge, and put back on the shelf. Never had any problems using this routine.
Mandrake
- x 695
That's correct. A lead acid battery left dead flat for a week or two will probably be history.Hell Razor5543 wrote:The problem may be due to the battery going flat and then being left like that for too long. A battery with a full charge can be left on the shelf for months (depending on the battery, 6 months can be achieved), but a battery that does not have a full charge can fail within a fortnight.
Actually you've got that back to front.The problem is, in effect, due to the strength of the battery acid; when fully charged the acid is weak as water, but as the charge drops so the strength of the acid increases. Some batteries can be recovered by a series of discharge cycles, others can't.
Repeated attempts to charge/discharge it may eventually revive it as you say, but chances are it will take a long time (many days or more) and it will never have the original capacity that it had, so its probably best to replace it if a couple of attempts to charge it fail.
Simon
1978 CX 2400
1978 CX 2400
- x 3296
I accept that I could be wrong re acidity changes. What I was told was that as the charge dropped, the acidity level increased, and, over time, this would rot the plates. However, as I said, I could be wrong (possibly by being given incorrect information).
