C5 Seat upgrade
C5 Seat upgrade
Hi I want to upgrade my seats but not sure if the wiring is present for heated seats etc does anybody else Know Ps It is a 2003 Hdi Exclusive wanted to fit electric heated seats but haven't got time to do the wiring if it is not already there, seats come with door cards so that wont be a problem.
Mitsubishi Delica 2.8 TD Exceed
Fiat Couple 20v Turbo
Citroen C5 HDI Exclusive
Re: C5 Seat upgrade
the wiring will be in place feel under the seats. you will need other items aswell do a search it was discussed on here a shart while ago think its a relay you will need and possibly a lexia session to switch it on in the computer
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: C5 Seat upgrade
Thanks for reply did do a search but didn't find it will have to look harder
Re: C5 Seat upgrade
look in leather seats as this is what most people do
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: C5 Seat upgrade
Am I missing something because I keep searching and I can't find anything about leather seats and have bought some now.
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Re: C5 Seat upgrade
http://www.frenchcarforum.co.uk/forum/v ... ts#p348233" onclick="window.open(this.href);return false;
Rick.
2013 Citroen DS 5 D/Sport
Re: C5 Seat upgrade
Thanks for that, could any body give me a bit more information please what do I need fuses relay and Lexia session??
Re: C5 Seat upgrade
once you find what you need try it first some cars already have it switched on so you wont need a lexia.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: C5 Seat upgrade
i think its an 80 amp maxi fuse you need
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: C5 Seat upgrade
Thanks again, will have to wait until I get them its just that once they are fitted I need to be able to move them back and forwards and don't think I can do that without power so was trying to be prepared as I don't want to keep putting them in and taking them back out again.
Re: C5 Seat upgrade
try the front passenger one first
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Re: C5 Seat upgrade
Hi getting seats tomorrow 28/1/13 have had a look at fuses and the fuses are there for the electric seats in the in car fuse box G37 38 39 40 surprised at this? Does any body Know wich fuse I need to fit under the bonnet?
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Re: C5 Seat upgrade
I think it's a 40A or 80A maxi fuse.. it goes in the side of the under bonnet fuse box, there is a space for it..
but you need to lift the fuse area out of it's plastic housing a bit... I struggled with this, think I may have broken a contact within the board, and the car was immobilised for a few days (I thought something else to do with standby mode was causing the problem)
I dont have my manual to hand to be sure on the exact location or current protection.
That was I think all I needed to get my seats to work.. (there are a couple of mini fuses in the fuse bay in glove box, but i think mine were already there, as you found with yours..
John
John
Re: C5 Seat upgrade
Thanks have got the seats now unfortunately somebody has cut the connector off the passenger seat so would like to get this before I fit seats so will try and get the fuse in and check that the power is getting to the cable but car needs to used all the time so not much time to mess about!
- qprdude
- x 10
Re: C5 Seat upgrade
Sounds like you have grounds for a bit of a refund. If you bought electric seats, surely the connector is part of the deal? I would be most annoyed at buying an electric iron without a plug, seems like the same thing to me.
Rick.
