XANTIA
pwatson
AllenR
phil
I was told that it was a factory made unit and could not be repaired
Its positon is just to the right of the sphere at the front of the engine. A metal pipe fromthe pump leads across to the hose which has a metal bracket attaching it to the engine, the hose leads off to another metal pipe on the body.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>many thanks for your interest.
Allen
Phil
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Allen
Phil
loe hofmans
LHM LEAKING FROM FLEXIBLE HOSE ON THE FRONT OF THE ENGINE. BEEN TOLD COMPLETE NEW FACTORY UNIT REQUIRED. ANYBODY CAN GIVE SUGGESTION ON HOW TO FIX
loe hofmans
JohnD
- x 72
Dave Burns
- x 3
The pipe in question is the high pressure feed to the power steering, no d-i-y repair is possible here because of the high pressure that needs to be contained, there are hydraulic hose repair outfits all over the place, this is your only hope of a repair otherwise you will have to get a new one or if you are lucky, one off a scrapper, I say lucky because breakers yards merely slice through rubber parts to get the engine out.
Good Luck
Dave
Good Luck
Dave
