Special Tool
Timmy69
Special Tool
Hi Guys
As some of you know i was in the process of changing my front pads when i found out that Halfords had given me the wrong ones.What i want to know is.Is there a special tool for winding the piston back in and if so what are they called and where do i get one ?.And what methods do you all use to wind it back in,if you haven't got said tool.
Thanks in advance
Timmy
Thanks in advance
Timmy
CGATCX25GTITURBO
- x 16
Re: Special Tool
wind em back with a wide enough piece of steel. or just look on ebay for the caliper tool
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Northern_Mike
Re: Special Tool
Timmy69 wrote:Hi Guys
Thanks in advance
Timmy
Tool can be had from Halfrauds for about £30 IIRC, or it appears exactly the same tool as Halfrauds sell can be had for £12 via Amazon
http://www.amazon.co.uk/Laser-1314-Cali ... B002V72SHS" onclick="window.open(this.href);return false;
CGATCX25GTITURBO
- x 16
Re: Special Tool
Rattiva_Mike wrote:Timmy69 wrote:Hi Guys
Thanks in advance
TimmyI used a flat bladed screwdriver with the end taped over in case it slipped out of the slot
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
- x 94
Re: Special Tool
look here
http://www.frenchcarforum.co.uk/forum/v ... =3&t=42808" onclick="window.open(this.href);return false;
Regards, malcolm.
Timmy69
Re: Special Tool
I read the comments in the amazon link and not one said they had used it on a citroen..i thought the actual piston on a xantia actually screwed back and not pushed back..I don't know i am completely confused now lol
Timmy
Timmy
- x 8401
Re: Special Tool
It screws back Timmy...
I have made a very successful rewind tool (ask Xac!)
It's basically a piece of square bar the size of the piston cutouts welded to a cheap 22mm socket. The length of the bar is juts a little more than the width of the piston face. Wind them back with your socket set ratchet bar.
I'll take a picture of it later and post it up.
The tool also doubles as a special tool for a 4HP20 gearbox for which it was originally made!!!
- x 94
Re: Special Tool
the wind back tools you see for sale were designed specifically for wind back caliper pistons, they will also work on push back pistons alike,Timmy69 wrote:I read the comments in the amazon link and not one said they had used it on a citroen..i thought the actual piston on a xantia actually screwed back and not pushed back..I don't know i am completely confused now lol
Timmy
all cars with calipers on all 4 wheels have wind back pistons were the hand brake mechanism is in the caliper ( this is not just a citroen system )
Regards, malcolm.
- x 94
Re: Special Tool
CitroJim wrote:It screws back Timmy...
the proper tool also puts just enough pressure on the piston to aid its retraction
Regards, malcolm.
Timmy69
Re: Special Tool
Ok thanks again guys you have all been Marvellous as usual
Timmy
Found This
http://www.ebay.co.uk/itm/BRAKE-CALIPER ... 484babb739" onclick="window.open(this.href);return false;
Do i need right or left hand thread ?
Timmy
Found This
- x 94
Re: Special Tool
depends if a XANT you just need the right hand threaded tool, but a C5 will need both as one caliper winds back clock wise and the other anti clock
Regards, malcolm.
CGATCX25GTITURBO
- x 16
Re: Special Tool
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Timmy69
Re: Special Tool
Nice Price but if you was only wanting one for the odd car why buy all that lol..Got mine today but not actually had a chance to use it as companies keep sending or selling me the wrong pads as shown in my other Topic http://www.frenchcarforum.co.uk/forum/v ... =3&t=42805" onclick="window.open(this.href);return false;
Timmy
Timmy
CGATCX25GTITURBO
- x 16
Re: Special Tool
Always nice to have the tools available, quite a few different cars in the the family and friends circleTimmy69 wrote:Nice Price but if you was only wanting one for the odd car why buy all that lol Timmy
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
