2006 Citroen Relay Van (melted connection)
crookie83
Unread post by crookie83 »
hi,
can anyone tell me what this connection is or called that's situated right next to the oil cap? as you will see in the picture it looks as though it has been melted.
Any help would be appreciated.
Bick
x 43
Re: 2006 Citroen Relay Van (melted connection)
Unread post by Bick »
looks like the cam shaft sensor on a 2.0l hdi engine
crookie83
thanks for the reply, any idea as to why this would melt? is it a common thing on these Citroen?
Mandrake
x 695
Unread post by Mandrake »
It looks rather close to exposed exhaust pipe - notice the oil filler cap is melted on one side as well. :shock:
Are you sure there isn't a heat shield missing off the exhaust ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 3296
I would definitely agree with Mandrakes' comment.
crookie83
yes its quite possible that there is some sort of heat shield missing i will get that looked at.
This wouldn't cause the indicators to fail would it?
Mandrake
x 695
crookie83 wrote:yes its quite possible that there is some sort of heat shield missing i will get that looked at.
Can't see how it would, but it will stop the engine running if it gives way completely...
Simon
1978 CX 2400
Bick
x 43
looking at it it looks like your egr valve is passing hot exaust gas - looks like you need a new egr. no other heat shield is fitted to the egr valve only the one on the flexi pipe but i can see that is still fitted.
crookie83
Bick thanks i will have egr valve replaced.
Your help is much appreciated.
