C5 2002 - Centre Display Screen
MaxPrimal
Unread post by MaxPrimal »
Hi guys,
My 2002 C5 Exclusive has the Sat-Nav option with the colour display. Now the display is not amazingly sharp which I put down to being 10 years old, but last night while driving the screen flickered a bit and suddenly became very sharp in terms if colour, then went back to "normal". So I assume from this the connector may be slightly loose in the back of the screen.
I had a look at the display housing and there are no screws etc in it and a reasonable pull did not seem to want to make it move or come off.
So how do I get to the screen to check the collector? Can I get the centre housing off the display and if so how? Or do I get to the screen another way?
Max
2008 RENAULT LAGUNA 3 EXPRESSION DCI 130 - Satnav, Bluetooth and more...
Citroenmad
x 110
Re: C5 2002 - Centre Display Screen
Unread post by Citroenmad »
Im not sure about the once with the satnav screen, however, with the normal screen the surround does just pull off and reveals screws to remove the screen. They are leavered at the top slightly and pulled
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
