At least one dent and scratch on every panel:
Dog chewed interior as standard:
Timing belt was 30k overdue, and looked it! Full timing belt kit, water pump, aux belt and tensioners to the rescue:
Every suspension bush and joint front to back has been replaced, handles a lot less like a block of cheese now:
New arms, trackrods, drop links and brakes, why not:
4 wheel alignment after suspension overhaul. Oh yes, 4 new Dunlops to go with that:
Then it was time to tackle the rust, didn't look so bad when I bought it
Rust cut out:
Nearly there:
That looks more road worthy!
What I don't have pictures of!
*Replacement low milage gearbox and new linkages.
*Genuine OE clutch kit
*New radiator, fan relays, temperature sensors, coolant
*New springs all round, strut bearings
*Interior stripped out, vaxed and thouroughly de-dogged!
*Loads of other stuff!
Thanks for reading, I hope it entertained.
