Howdy,
I seem to have broken a small rubber hose which comes out of the injector on my XUD Xantia. It looks like a breather hose, sure its creating an air leak which is making the fuel drain back into the tank.
My question what OD size pipe is this to replace? Its the righthand most injector, doesnt look like it attaches to the other injectors.
injector hose replacement
fotobright
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
- x 1240
Re: injector hose replacement
That will be a leak off pipe, if you go to a motor factors you can buy a length of it and cut it to size. If it broke its obviously brittle so I should change all of them.
- x 94
here is what you need
http://www.amazon.co.uk/Diesel-Leak-Spi ... B0049HKO5G" onclick="window.open(this.href);return false;
GSF do sell these kits
Regards, malcolm.
fotobright
Leak off pipe, excellent!,
GSF is just round the corner too...
merci
merci
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
