Citroen service.com question
Rhothgar
(Donor 2026)
x 221
Re: Citroen service.com question
Unread post by Rhothgar »
Probably be in Body Section
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'd check the upper portion of the door assembly (ie; window frame) is tight to the body. A lot of leaks track down from gaps here.
x 94
Unread post by citronut »
superloopy wrote: The water can be seen trickling in 'under' the front passenger door from somewhere,
i would remove the door card/trim to check if the membrane is still there/intact
Regards, malcolm.
x 2938
Look for weatherstrip instead of seal
Sorry tried that myself and it doesn't work, the seals are under 'side panel door frame' look for part number 9023VS and it should take you to the correct page at least.
x 1489
Bodywork - side structure - side panel. Then you get choices for 3 and 5 door models "SIDE PANEL SIDE DOOR FRAME" and they are in there.
These are example ones for later cars, 3 door, then 5 door:
Part Number Description Quantity Price excl. VAT Price incl. VAT
00009025AK DOOR ENTRY SEAL 44.87 GBP 53.84 GBP
00009025AL DOOR ENTRY SEAL 44.18 GBP 53.02 GBP
x 94
here are the part No.'s listed for a 3 door
9025 A6
RP 9025 AK
DOOR ENTRY SEAL
LEFT
- UNTIL RPO 11344
9025 J0
RP 9025 AK
LEFT
- SINCE RPO 11345 UNTIL RPO 11508
9025 A7
RP 9025 AK
RIGHT
- UNTIL RPO 11344
9025 H8
RP 9025 AK
RIGHT
9025 S4
RP 9025 AK
- SINCE RPO 11509 UNTIL RPO 11840
9025 AK
- SINCE RPO 11841
and for 5 door
9025 A8
DOOR ENTRY SEAL
LEFT
- UNTIL RPO 11344
9025 H9
RP 9025 AL
LEFT
9025 A9
RIGHT
- UNTIL RPO 11344
9025 H7
RP 9025 AL
0RIGHT
9025 S5
RP 9025 AL
9025 AL
- SINCE RPO 11841
9025 C0
REAR HINGED DOOR SEAL
LEFT
- UNTIL RPO 11344
9025 J2
RP 9025 AN
DOOR ENTRY SEAL
LEFT
9025 C1
RIGHT
- UNTIL RPO 11344
9025 J1
RP 9025 AN
DOOR ENTRY SEAL
RIGHT
9025 S8
RP 9025 AN
9025 AN
- SINCE RPO 11841
Regards, malcolm.
Rhothgar
(Donor 2026)
x 221
A lot cheaper than welding in the long term and the ear-ache between now and then!
