removing keypad immobiliser
wirdip
Unread post by wirdip »
Hi folks,
I have a 1996 806 SRDT with keypad, is it much of a job to remove this and is it a good idea to do so.
Regards Wirdip
x 8427
Re: removing keypad immobiliser
Normally, and it seems to hold on most, is that you can disconnect the keypad with the engine running and then you'll never need it again. This is the case with most 1.9TD engined PSA vehicles although I cannot guarantee it'll work for sure on your 806. Noting lost in giving it a try...
But why? They're pretty trouble-free and I can't see any difficulty in having to enter a four digit PIN before you can fire it up. Two of my cars have keypads in working order but then they both have the only PSA engine I know for sure that the keypad cannot be disconnected...
Unless you have a very good reason then I'd leave the keypad in place and in working order.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
CitroJim wrote:But why? They're pretty trouble-free and I can't see any difficulty in having to enter a four digit PIN before you can fire it up.
Because the keys wear out in time and leave you stranded :wink:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8427
Well, change the PIN regularly so the keys get even wear then :wink:
Northern_Mike
Then you forget the PIN and it leaves you stranded :-o
Sent from my GT-I9300 using Tapatalk 2
x 8427
Rattiva_Mike wrote: Then you forget the PIN and it leaves you stranded :-o
Well, one credits one who owns a keypad car sufficient intellect and savvy to ensure that doesn't happen...
Northern_Mike
You'd be amazed Jim. Only last night I was dealing with a Doctor who manages to lock her network account out every single week because she screws the password up. Intelligent lady, obviously. Not great at remembering things.
keithn410
Unread post by keithn410 »
hi, its pretty easy to remove keypad. turn ignition on and enter pin number into keypad until green light comes on on the keypad. once this is done remove keypad cluster using small screw driver and you will see a multi-plug connector in the back of the keypad. unclip this and your keypad is disabled. its pretty simple to do but please be aware your vehicle is no longer secure once youve done this. :)
x 8427
keithn410 wrote:hi, its pretty easy to remove keypad.
Indeed it is but...
For anyone thinking of doing this, there is one exception where it won't work - that is on the 2.0TCT engine with the Bosch MP3.2 Injection. An engine commonly found in Xantia Activas and many XMs along with some Pug 406s...
I am not aware of any other exceptions but would urge caution around 2.1 Diesels with the Lucas EPIC pump as I have no knowledge as to whether or not the keypad can be disconnected in the manner Keith describes...
Rattiva_Mike wrote: You'd be amazed Jim. Only last night I was dealing with a Doctor who manages to lock her network account out every single week because she screws the password up. Intelligent lady, obviously. Not great at remembering things.
Often goes with the territory Mike.. Those with a brain the size of a planet are often rubbish at the simple things we take for granted...
Northern_Mike
Yes, having a brain the size of a planet, I am aware of these issues. :P
x 8427
Takes one to know one I guess :roll: :lol: :lol:
wirdip
Thanks to all you large brained contributors for your help. Nice to know that I have sparked such a lively thread. Just as a matter of fact is this procedure reversible????
Regards Alan
x 8427
wirdip wrote: Just as a matter of fact is this procedure reversible????
Yes it is Alan, so long as you can remember the last PIN used before disconnecting the keypad...
Homer
x 16
Unread post by Homer »
I would guess those still connected must have been the good ones. From what I remember they were anything but trouble free in the early days and disconnecting was almost standard procedure.
spider
x 77
Unread post by spider »
I can remember the early days too. They would not work / refuse code / display both lights, then you'd come back an hour later and they'd be fine. I suspect it was corrosion on the IC1 connectors the large round ones at the front on 106's and 406's that were some of the cause, although S1 306's the wiring seemed to on some models appear to corrode from within. To be fair the newer shape did not do that as much.
Am interested to know about the two models that refuse to have said keypads disconnected. Jim, have you set them to be in "auto" mode, ie green light for 30 seconds automatically when using plip method ? If that does not work then I have to suspect these models have something going on in the CPH unit to prevent it...
Andy.
