Berlingo 2000 reg wiper not working
andysmithe22
- New User
I have a Citroen berlingo and my front wipers have stopped working. The windscreen washer still works, I've tested the motor and it works, I have 12v to the plug for the motor but still nothing. Any help would be much appreciated. I am learning as I go along so please be gentle with me if I don't understand some things. Thank you
- x 1240
Re: Berlingo 2000 reg wiper not working
I would think there should be a fuse for it somewhere.
addo
- Sara Watson's Stalker
- x 95
G'day Andy, if the RPO is 8600 or higher it's a multiplex car.
In these cases, usually the underbonnet fusepanel has failed internally - does it keep popping a fuse there? Substitution with a known working unit, is the easiest fix. Pre-multiplex cars are simpler, you can follow the wires to determine where the fault lies.
