Dispatch Side Loading Door.
merlecollins
Unread post by merlecollins »
Hi all,
Just a quickie....
I know these are temperamental from when I owned a Fiat Scudo of the same shape.
The drivers side loading door is just too far forward, it is vertically in line OK, but my drivers door is catching it when I get in and out.
Does anyone have any tips on how to adjust the loading door to move it back slightly, probably about 5mm will be great :wink:
oneday
Re: Dispatch Side Loading Door.
Unread post by oneday »
sorry cant help you with that one i would need to see the vehicle to work it out
306 1.4 LX MERIDIAN
merlecollins
Its got me bamboozled mate.... :?
All the bolt fixings that would allow movement side to side are factory set, so I'm flummoxed as to how it has moved forward in the first place...
I will persevere :arrow: :wink:
oneday wrote:sorry cant help you with that one i would need to see the vehicle to work it out
oneday
where there is a will and all that good luck with it im sure you will sort it
306 1.4 LX MERIDIAN
oneday
just googled about ajusting the side door there is a lot of info on this problem even seen one about hidden torx screws
306 1.4 LX MERIDIAN
Sean602
Unread post by Sean602 »
can you lift the bottom roller sled/carrage? if the bearings are collapsing the door will tip forward. also mine has lost the black nylon socket for the finger at the top. Off to the scrappy when they open tomorrow.
Wheres the hidden torx screws and the adjustment?
Sean
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
merlecollins
Don't think it's the roller bearings Sean602 as the door itself is nicely in line with the panel at the back and the drivers door, but just too far forward. If I could just adjust it back a bit i'd be laughing! :lol:
Sean602 wrote:can you lift the bottom roller sled/carrage? if the bearings are collapsing the door will tip forward. also mine has lost the black nylon socket for the finger at the top. Off to the scrappy when they open tomorrow.
Sean
