Citroen C5 1.6 HDI Steering wheel angle sensor recalibration
floggmolly
I Have a 2005 Citroen C5 1.6 Hdi And the esp light is on. I Put it on the lexia and it shows up steering wheel angle sensor. How do i recalibrate it?
horsedentist
Re: Citroen C5 1.6 HDI Steering wheel angle sensor recalibra
I have exactly the same problem on my 2.2 HDI the recalibration section is under the suspension ecu and will come up with instructions on the lexia when selected but I think you need a big flat area to do it, if I have read it correctly, as you need to drive it to recalibrate. Firstly in a straight line then moving the steering wheel a a quarter turn right and then left.
I haven't done mine as yet because i need to find a big enough area to do it.
CGATCX25GTITURBO
- x 16
http://www.frenchcarforum.co.uk/forum/v ... =3&t=42713
I had it with my Picasso.. it wasn't a software issue
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
horsedentist
Well mine hasn't been apart all that happened was, I took it and had the wheels balanced, a few hours later the esp light came on. I have read that if you mess with the tracking at all you have to recalibrate it so presumably swapping wheels about has the same effect.CGATCX25GTITURBO wrote:http://www.frenchcarforum.co.uk/forum/v ... =3&t=42713
CGATCX25GTITURBO
- x 16
Does it come on as soon as you turn the key on and then go off and come back on again? Does the deactivate switch work?
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
horsedentist
Yep comes on when you switch the ignition on and doesn't go off at all switch doesn't work. If I clear the steering sensor fault it will stay off until I drive off then it will come back on and the fault will be back.
Oh and the service light comes on with it too.
Citroenmad
- x 110
Is that the only error code stored?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
horsedentist
yes "steering wheel sensor incoherent " I have been driving it round for weeks before this with no problems at all and as I have been working on other problems on it I would have noticed this fault had it been there. The problem is that it effects the abs as well so that's why the esp drops out. I will post the results when I get round to recalibrating it and let you know if it sorts the problem.
CGATCX25GTITURBO
- x 16
Sounds like mine.... I turned the steering wheel to the left a couple of turns so the steering wheel was in the straight a head position, started the car and the ESP light went out. I then pressed the button and it deactivated.horsedentist wrote:Yep comes on when you switch the ignition on and doesn't go off at all switch doesn't work. If I clear the steering sensor fault it will stay off until I drive off then it will come back on and the fault will be back.
have you tried it in any other straight ahead postition, wheels to the left or right?
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
horsedentist
Took the C5 and had the tracking done today as I thought it was silly not too if I was going to recalibrate the steering (was miles out) recalibrated the steering cleared all the faults and it is working fine no more esp/asr faults.
Mandrake
- x 695
Sounds like your tyre fitter was lazy and adjusted the tracking only on one side.horsedentist wrote:I took it and had the wheels balanced, a few hours later the esp light came on. I have read that if you mess with the tracking at all you have to recalibrate it so presumably swapping wheels about has the same effect.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
horsedentist
Well it was strange because I had done a few hundred miles in it over the last few weeks and no problems at all until I had the wheels balanced and they swapped them about when they put them back on. Then about 20 miles later the bloomin steering fault popped up put esp/asr and service light on. I only had the tracking checked because I thought if I was going to reset the steering I might as well have it done so all avenues were covered. Any way she runs like a dream now done a couple of hundred miles and no lights are on and no snide comments from the computer
