The interior switches were the speed setting and direction the bulbs have gone. But the cold heat one ok.
So I wanted to fix the bulbs and the easyest way to do it.
306 hdi interior bulbs gone
- x 1240
Re: 306 hdi interior bulbs gone
If you mean the warning lights on the instrument panel, you will have to remove the panel to gain access to the lamps, shouldn't be to fifficult a job.
Welshy_Pete
I mean the heater speed control and heater direction control part near the radio.Peter.N. wrote:If you mean the warning lights on the instrument panel, you will have to remove the panel to gain access to the lamps, shouldn't be to fifficult a job.
- x 1240
I would think the same applies, you will have to remove the controls to get to the rear.
MichaelH
If not done yet, it is moderately simple but you need to remove the radio first (you may need the Clarion keys (£5 a pair) which slide under the radio below the black surround (there are two slots are only about 1mm high so difficult to see - I have managed with two knife blades but doesn't always work).
Once the radio is out you can remove the centre panel surround.
Then turn all the dials (heater controls) fully clockwise then carefully prise off the face plate and dials with a penknife blade. Bulbs then jut pull out.
Reasembly is reverse but make sure dials are still in the right position, Everything else just clicks back in.
The most frustrating is getting the radio out if like me, you use knife blades. You'll do it all in the hour if you already have the bulbs
Mike
Mike
UK Midlands currently with C5 (X7) Exclusive 2.0 HDI + 2 Pug 306s (Meridian and L) and a Pug 206L a/c
Previous C5 1 Exclusive 2.0 HDI, Pug 407LX HDI, 2No. Pug 406s LX HDI, Pug 309GLD, Pug 205GL, Pug 505GL, Pug 604SE, Pug 504ti
