ok another radio unlock request
Sean602
Unread post by Sean602 »
so took the battery out to give it a charge DOH!
Clarion PU-2294A(C)
barcode/SERIAL NO on radio CL040161032734C
VIN VF7**************[VIN obfuscated, can be read by forum staff]
06 DISPATCH
any help appreciated
Sean
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
oneday
Re: ok another radio unlock request
Unread post by oneday »
if this is the standard radio it shouldnt need to be coded as they are coded to the vin
306 1.4 LX MERIDIAN
Sean602
ive told it that but its asking for the unlock code, standard radio.
which part of the VIN is the code then?
kissing the lash
orange 2cv
red Dyane( in bits)
oneday
you may need someone with a lexia to sort it out for you. have a look in the supersticky section for lexia locations
306 1.4 LX MERIDIAN
Northern_Mike
oneday wrote:you may need someone with a lexia to sort it out for you. have a look in the supersticky section for lexia locations
I think these are just a standard head-unit asking for a normal 4 digit code aren't they?
Now, if you were replacing the headunit in a Berlingo Multispace or C5, you'd definitely need a Lexia!
oneday
not to sure about these radios but if it is the normal 4 digit code im sur someone will be along soon to sort it its just a quiet time with it being christmas
306 1.4 LX MERIDIAN
x 3296
You might want to try The Birdman. He is a member of the forum, and seems to know all the necessary codes for every Citroen going.
http://www.frenchcarforum.co.uk/forum/m ... le&u=11308" onclick="window.open(this.href);return false;
Hope this helps.
Sean602
Thanks for the replies so far chaps, unfortunately it seems the radio has to either go in to have the eeprom read or for someone to consult the "List" of which radio clarion supplied for that chassis number, could be a trip to Citroen main dealer ho hum...last owner never had the problem as he never had the radio out or battery changed so that route for the radio code didn't work :(
Sean
edit - seems the simplest solution is the best, phoned the dealer that supplied the van originally and a couple of questions to verify that i had the whole van and was legal owner just gave me the code as well as a potted history so problem solved thanks tohttp://www.duthiesmontrose.citroen.co.uk/ =D>
kissing the lash
orange 2cv
red Dyane( in bits)
oneday
nice and easy in the end then glad you got it sorted
306 1.4 LX MERIDIAN
