drain holes c5
thefrenchconnection
drain holes c5
Unread post by thefrenchconnection »
were are the water drain channels on the mk1 c5 ive found the ones in the doors and the front scuttle panel not sure were the rest are.
marc
2001 c5 2.0hdi sx
oneday
Re: drain holes c5
Unread post by oneday »
why do you want to find them
306 1.4 LX MERIDIAN
thefrenchconnection
Re: drain holes c5
got a leak in the rear footwells carpets are wet through in the back but dry in the front of the car.
oneday
Re: drain holes c5
is your car a hatch or an estate
306 1.4 LX MERIDIAN
thefrenchconnection
Re: drain holes c5
hatch, no sunroof
oneday
Re: drain holes c5
two places ive found water leaks on mine are the ariel base and around the rear hatch seal gets into the boot thenruns forward under the rear seats and onto the rear mats
306 1.4 LX MERIDIAN
thefrenchconnection
Re: drain holes c5
took door card off this afternoon and noticed the plastic membrane was stuck down with cellotape and had a rip in it so going to get some heavy duty polythene sheeting and cut it to size and seal it in properly so hopefully should cure the problem.
marc
2001 c5 2.0hdi sx
thefrenchconnection
Re: drain holes c5
membrane on(managed to use a waterproof rubble bag ) but all the door plastic clips are busted contacted citroen 83p each looked on ebay 30p each,should be a easy cheap fix.
