c5 estate tailgate keeps opening!
easypeasy
- New User
Hi folks. I'm hoping someone can help me with this problem. I have a 2002 diesel estate and the last week each time I open the door to exit the tailgate opens as well. When I use the fob to open the car this also opens the tail. I have to drive with the doors locked from the inside now as I have dogs so not too safe for them!Any ideas folks? Cheers
cachaciero
- x 9
Re: c5 estate tailgate keeps opening!
I assume that you are refering to the rear window. Tailgate window open switch is stuck in open position, failure of this switch is quite common. If you are refering to the complete tailgate opening then again it is likely to be the switch permanently made. In both cases gaining acess to the wires and disconneting the switches will prove if it is the switches.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
easypeasy
- New User
It is the tailgate that is opening. The window has never opened. I will try the wiring and see if that's any difference. Thanks
