xsara Picasso error code p0340, p0480
anif555
New User
Unread post by anif555 »
Hi my xsara Picasso 05, wouldn't start, did diagnostic and had no codes. so somehow figured out it's the high pressure diesel pump.replaced it with fiat scudo pump (same part no).car started fine but had engine management light on.diagnosed again and above codes appeared.so the fella erased the codes and engine management light went off.but the error codes still came back on the diagnostic computer. now I have done 100 miles. Light never came back on in the car. and is doing 39mpg.but I (just feel)like the car is not giving maximum power when accelerating.please help and advise me.thank you
P0340 - CAMSHAFT/CRANKSHAFT SYNCHRONIZATION
P0480 - FAN HIGH SPEED CIRCUIT
x 1055
Re: xsara Picasso error code p0340, p0480
Unread post by wheeler »
anif555 wrote: P0340 - CAMSHAFT/CRANKSHAFT SYNCHRONIZATION
This fault code combined with lack of power & the fact the timing belt has been disturbed would make me go back & check the timing is set up 100%.
