[solved] C3 sensodrive "stuck" - battery - thank you
Michal
Unread post by Michal »
My C3, after staying on the driveway for a couple of weeks (and cold weather), refused to turn the engine on one morning. I suspected the battery, so charged it (I thought) and tried again. It displayed the dash and snowflake to me, instead of the gear number. I could not change the gear to N. The car was in the 1st gear, so I could not move it neither. My thinking was, it's the sensodrive, packing up...
I found this forum and contacted CitroJim. Jim was enormously helpful, scanning the car with the software on his laptop and after a moment, suggested that the battery may be not really charged. The computer was detecting 8.8V on the battery. It was quite embarrassing :oops: :) I sorted the battery (this time properly), looked through the car manual and found out the gear reinitialisation procedure. After following the procedure and about half a minute of weird noises from the gear (gears changing?), the car displayed 1 and was ready to go!! :-D
Jim thank you for helping and for the time you spent on it, not mentioning that you had to travel to my place, as my car was stationary.
Lessons learned: a) check the battery first, use some meter; b) look through the car's manual to refresh memory;
The re-initialisation procedure of sensodrive on my C3 (e.g. after the battery was disconnected):
- switch on the ignition
- press on the brake pedal and keep pressing
- wait until you see "N" or a gear displayed (approx. 30s)
- release the brake pedal
oneday
Re: [solved] C3 sensodrive "stuck" - battery - thank you
Unread post by oneday »
thats what i like a nice simple repair and good help from jim
306 1.4 LX MERIDIAN
x 8191
Michal, I'm absolutely delighted to hear this :-D Excellent news!
I was good to meet you on Sunday. Both the XM and I thoroughly enjoyed the trip over to see you and the poorly C3 :-D
It was good to look at something other than a Xantia or an XM for a change :)
And thanks for adding some very valuable knowledge to the forum :-D
