Cat
- x 5617
Re: Cat
Depends on the type of driving, Short trips with a long time to go cold in between will bung it up fairly quickly. They need a good long run at reasonably frequent intervals and they will burn off the crap when they get good and hot.
Under those conditions they will sometimes start an automatic regeneration process, you may see all the electrical equipment come on and notice a marked increase in fuel consumption, along with a significant amount of smoke. If so just keep on until the process is complete.
Around 100 miles on a clear motorway late at night is often a good time to do it.
Ideally it wants to be doing 4,000 revs, so fourth gear and hustle along.
SaabC5
Re: Cat
Hustle along? At 4000rpm in 4th my 2.2 will be doing 100mph+myglaren wrote: Ideally it wants to be doing 4,000 revs, so fourth gear and hustle along.
Third gear at about 60mph is a bit more legal if you know what i mean.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Monkeyfeet
Re: Cat
Once you've got the thing off the car, then successfully undone it's four bolts, by the time you've smashed out the dpf with a big fat hammer and a rod - I'll bet that you won't be able to resist smacking out the cat as well.........
(well while you're there....)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
