wet boot in Xsara from rear screen
3ps
Unread post by 3ps »
I found the boot carpet foam was a bit wet. After an inspection I noticed the rubber seal on the outside of the rear windscreen was off a bit in one corner.
Also, where the rubber seal end points join, just near the wiper, one is out of kilter a bit.
What is the best way to remedy this? Not sure I want to remove glass etc.
Is putting black Sikaflex or similar sealant under the original seal too much of a bodge?
oneday
Re: wet boot in Xsara from rear screen
Unread post by oneday »
if it stops the leak why not you can do a better job when the weather is better
306 1.4 LX MERIDIAN
