Dpf Removal
wizzer59
Dpf Removal
Unread post by wizzer59 »
Hi guys have removed the dpf from my C5 this afternoon, I have drilled out all of the filter material from it, but before I bolt it back on I was just wondering if I need to remove the stuff from the bit left on the car? or is that something else?
The Birdman
Re: Dpf Removal
Unread post by The Birdman »
The bit left in the car will be the CAT , have you changed software ?
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
wizzer59
Re: Dpf Removal
Not yet, probly have to pay one of the many companys around to do it :? . So I don't don't need to touch the cat yes??
The Birdman
Re: Dpf Removal
I`d leave CAT alone at miunte , have you lexia ? Any lights on yet ?
wizzer59
Re: Dpf Removal
yea anti pollution fault and in limp mode, took it to my local garage and he said it was saying dpf blocked and several other things I can't remember #-o
wizzer59
Re: Dpf Removal
He also said he couldn't get it to reset anything :(
wizzer59
Re: Dpf Removal
oh another fault code was something about glow plugs #-o
The Birdman
Re: Dpf Removal
You need to tell the car its been filled with Eolys and had a new DPF , then clear codes ,
after that go into each area involved and tell car it hasn`t got a DPF , that`ll do until you get it mapped .
wizzer59
Re: Dpf Removal
Do I do that in French or will it understand english :wink:
wizzer59
Re: Dpf Removal
Sorry couldn't resist, thanks for that I guess your talking lexia here :oops:
