hi all,
any help or advice would be much appreciated as i am at wits end, unsure what to do for the best
basically my c5 2.0hdi is dead, i heard a loud wizzing that i believed to be the turbo, followed by some rather horrible rattles, clouds of smoke, major loss of power, then total death.
where would i beging to start getting this repaired, as could be turbo only, or more likely to be turbo and possibly engine by the sounds of it. or is it ready for the scrap heap?
can anyone reccomend a decent garage, or enthusiast localish to peterborough?
Regards
Paul.
Dead 04 C5 2.0 HDi VTR
SaabC5
Re: Dead 04 C5 2.0 HDi VTR
Did the engine rev its nuts off?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 2943
Have you checked the timing belt? The symptoms could suggest a broken belt and broken valve rockers.
jaip
Cambelt was changed 1000 miles ago and is still intact, no it didnt over rev, if anything it just lost power, just before it stalled the information screen said low oil pressure.
jaip
The turbo noise did stop, before it died, am i right in beleiving if the turbo seized the oil would just flow through as its only sealed when spinning?
Northern_Mike
Or the belt wasn't tensioned, properly, has jumped a few teeth and had much the same effect. Sounds like it could be belt-related judging by the description and that it was only done 1000 miles ago.Gibbo2286 wrote:Have you checked the timing belt? The symptoms could suggest a broken belt and broken valve rockers.
Turbo failure probably isn't too bad if it's anything like as accessible as the Xantia HDI 110. 2nd hand turbos aren't dear, providing it's not injested too many bits of the turbo through the engine. I say this from the experience of having a Saab 900 Turbo eat parts of it's turbocharger with no ill effects..
jaip
Would the turbo failing cause low oil pressure warning?
Northern_Mike
It could do, depending on how the turbo had failed, and if all the oil had suddenly been dumped into the exhaust side of the turbo, but I'd not expect it to do so immediately. My Saab ran literally for weeks with failing turbo oil seals. It was fine while driven, but idling at lights could eventually disappear in a cloud of it's own oil smoke from oil leaking past the turbo seals.jaip wrote:Would the turbo failing cause low oil pressure warning?
jaip
Managed to check the turbo shaft and there is loads of play in it, in out and up and down, and no oil left in the car, it was fine and full in the morning.
Northern_Mike
Is there evidence the oil's gone down the exhaust? If you've lost 4 1/2 litres, there will be, I'm sure..jaip wrote:Managed to check the turbo shaft and there is loads of play in it, in out and up and down, and no oil left in the car, it was fine and full in the morning.
jaip
Ive not got that far yet, although there was plenty of black crap covering the rear window, i will see if i can get the exhaust off... Found a turbo for under £100 second hand so it may be worth the risk of trying that. Looks a bugger to get to though.
Xantidote
- x 5
As Mike suggested earlier, might be good idea to check other parts of engine for any other damage (ie. cam belt & timing, camshaft integrity etc), before replacing the turbo. How long from the warning of low oil pressure, to the engine giving up - thinking here of crankshaft bearings
Martin
1995 Xantia TDLX (deceased
Northern_Mike
From experience, it also matters whether bits of the turbo have broken off and been sucked in and been smashed up by the pistons and been spat out down the exhaust - my Saab evenutally did this, and sparks were emitted from the tailpipe. Obviously a HDi has rather more compression than my 8.5:1 Saab did and it might have done damage to the valve gear and pistons.Xantidote wrote:As Mike suggested earlier, might be good idea to check other parts of engine for any other damage (ie. cam belt & timing, camshaft integrity etc), before replacing the turbo. How long from the warning of low oil pressure, to the engine giving up - thinking here of crankshaft bearings
If it were me, I'd be tempted to put some oil in it and see if it does actually turn over ok. If it does, all well and good, if not, it was broken already, so nothing to lose either way:)
jaip
Good idea
) thanks i will give that a go, got plenty of time off over crimbo so if gets past tuning over and starting i will get a turbo, there is one local at the breakers with 67k so hopefully get it with bits like the manifold and downpipe, should make it easier... If it comes out that is.
Xantidote
- x 5
Well, good luck with your investigations. Hope it's not too difficult or costly a repair job.jaip wrote:got plenty of time off over crimbo
Martin
