citroen dispatch (06)headlight bulb removal
as any one any idea how to remove the headlight bulb ,does the black connector just pull off as mine seems rather tight and i dont want to break it ,the problem i have is my main bulb keeps going out i have a feeling the bulb is not fitted correct because with a wiggle from the back and it comes back on ,any info would be great
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Re: citroen dispatch (06)headlight bulb removal
Block connector should just pull off. Common issues for intermittent bulbs are bulb incorrectly fitted (look for tab on bulb and slot inside light fitting for correct way up) also poor earth wire on lights and also loose wires on plug where previous owner has pulled out using the wires and not the plug.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
