C5 Starting fault
imperial21
C5 Starting fault
Unread post by imperial21 »
I have noticed that my C5 has started to have a funny starting fault, When i try to start it in the morning i turn the key as usual at the point where the starter motor should start it does nothing, If i turn the key backwards and forwards a few times it will start fine, Could this be a starter solonid or ignition switch fault ? Only happens when cold eg in the morning and gets worse in the colder weather or if the car has nt been used for a couple of days, I am sure the battery is fine, its nearly new and i dont think its anything to do with immobiliser as it beeps when that says the key is nt right. My C5 is 2ltr HDI.
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
x 1053
Re: C5 Starting fault
Unread post by wheeler »
Put a voltmeter or test lamp on the starter solenoid wire whilst someone is trying to start the car & see if there is power going to it, if no power there then most likely an ignition switch fault, if there is power there then most likely a starter motor fault. The immobiliser on this car doesn't inhibit the starter motor so you can rule that out for definite.
