Thung sound when reverse
Post Reply
begins
My Cars:
Post by begins »
Hi all,
Recently, my 2007 C5 started to produce a “Thang” sound when I reverse all the way to one side (left to right).
Is this a brake problem? Since I just change the front brake pad and the problem emerge shortly after that.
A friend who owned a C4, told me this is a common “design” problem in Citroen, true?
Kindly advise me and Thank you very much.
Regards,
coastline taxis
My Cars:
Re: Thung sound when reverse
Post by coastline taxis »
think this is linked to the brake problem you have poated. Sound like a caliper loose or siezed caliper or slide mounts. recheck the work youve done
begins
My Cars:
Post by begins »
coastline taxis wrote:think this is linked to the brake problem you have poated. Sound like a caliper loose or siezed caliper or slide mounts. recheck the work youve done
Can the calipers be repaired or serviced to resolve the jamming problem?
Thank you.
Regards,
begins
My Cars:
Post by begins »
Hi all,
Just an update here. The problem has been rectified.
I have changed the suspension arm bushings and the problem vanished.
Regards,
Post Reply
