Not sure if this is common with C5.
When I brake at the traffic light, the car will produce a clunk noise (sound like gulk) and I can feel that the car is like jerking backward. Something like when firing a riffle with a recoil (jerking)
Do you guys experienced this? How should I go around rectifying it? Now few things come to mind:
1. Brake oil level normal. Do I have to bleed again?
2. Change the hose to a steel one?
3. Front brake pad already changed, caliper jam problem?
Kindly advise me and Thank you very much.
Regards,
