Recommendation for Spark Plugs
begins
Unread post by begins »
Hi all,
Contemplating to change my spark plugs, any recommendation for a reliable brand/model for my 2007 C5 2.0L petrol?
Thank you very much for any recommendation and feedback :P .
Regards,
spider
x 77
Re: Recommendation for Spark Plugs
Unread post by spider »
Personally I like Bosch plugs, although I'm not sure if you have any specific requirements such as multi electrode or long life / platinum etc with your vehicle. :)
Andy.
begins
spider wrote:Personally I like Bosch plugs, although I'm not sure if you have any specific requirements such as multi electrode or long life / platinum etc with your vehicle. :)
Thank you for the reply.
This is a used car and the ex-owner is using a “4 heads” Bosch spark plugs (suspect it is a Platinum Ir Fusion Spark Plugs).
In the past 8 months of ownership, I would say my C5 is very sensitive to changes :( , so I will just stick to something there is highly compatible and reliable will do. I don’t mind to change the spark plugs on a more frequent basis.
Regards,
