Just put new rear calipers on my c5 ,I also found that one handbrake lever on the O S was seized . Removed both front calipers freed the off side one ,and lubricated the near side changed the brake pads and refitted . Now looking at the hand brake cables the outer cable is rusty where it joins the soilid pipe at the bulkhead, anyone know of a method of lubricating the inner cable . Don't fancy changing the solid pipes in the bulkhead.
Thanks .
