copper grease - where?
froggy
(Donor 2026)
x 4
Unread post by froggy »
Hi, after changing rear pads on my Xantia, I have found I have a squeak coming from the brakes, as I depress the brake. Someone said , apply copper grease, but where? any help gratefully received, cheers.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
old'uns
x 127
Re: copper grease - where?
Unread post by old'uns »
BACK of the pads, definitely NOT the front 8-[
usually a small smear between the pad/the thin metal thingy- brain dead, can't remember techie term!/piston
anti-rattle spring?
x 3296
You probably mean the shim.
old'uns
x 127
I did, yes, as i said brain fade
x 3296
I would suffer from brain fade if I could only remember where I left it, but it faded!
