where i have to register advance the retardo? Mechanical di
ektor
Unread post by ektor »
where i have to register advance the retardo? Mechanical diesel injection pump, LUCAS VARITY
type DPC
Bick
x 43
Re: where i have to register advance the retardo? Mechanica
Unread post by Bick »
you are in the right place what is it you need advise on?
ektor
how can I register advance and retardo in this pump in the picture. I want to know the proccedure.thank you
horsedentist
Unread post by horsedentist »
I think he wants to know how to advance or retard the the pump timing
Bick
x 43
that is not a simple job and a dti is needed the check the pump timing - a manual like a hanes gives good instruction on this.
ektor
where I can find this manual? thank you very much it is very important for me to find it.
horsedentist
Try ebay just put in " Haynes manual XXXX" XXXX being the model of your car.
x 5674
ektor is in Albania and may not have access to the Haynes manuals as readily as we do.
spider
x 77
Unread post by spider »
I'm not sure you can really advance it properly as the pump on the DW8 (the same as the TUD5) only will bolt in one place the holes are not elongated so you cannot 'turn' the pump.
The timing you could probably turn the pulley I guess but if its out there's probably more going on than its position.
Andy.
x 3296
I wonder if the belt jumped by one tooth? That would put the pump timing out, wouldn't it?
If the info on the picture is anything to go by, the car in question is a Xsara. What we need to know is if it is a Xsara Picasso or not, and the year (to find the right Haynes manuals).
ektor
my car peugeot 206 1.9 1999 have the same pump with xsara. so the pump is the same that is shown in the picture. if tou will be able to find the right manual ilI will appreciate. thank you very much
x 3296
I have just looked on ebay (Haynes Manual 206) and found this;
http://www.ebay.co.uk/itm/Mark-Coombs-P ... 4abf4630bf" onclick="window.open(this.href);return false;
I don't know what the exchange rate, but I hope that this helps.
