Hi folks,
following my last post (regarding odd behaviour from indicators) I have fitted yet another indicator stalk. At first this worked fine (for about 20 mins) then when indicating just a solid light (no flashing) at both dashboard and indicators so I am having to click stalk on and off to get desired effect. Then following day when starting from cold everything worked fine again untill car gets warm and then solid light again. this has now happened on 3 occasions. Can anyone think what heat might effect in the indicator system, I am perplexed to say the least. Any ideas out there????????
Regards Wirdip
peugeot 806 haunted indicators follow on
addo
- Sara Watson's Stalker
- x 95
wirdip
Re: peugeot 806 haunted indicators follow on
don't think it's multiplex it's a 1996 model, stalk was second hand
addo
- x 95
wirdip
which of those would be affected by heat do you think?. Works fine when temperature inside car is cold, stops when warm.
addo
- x 95
wirdip
When flasher stops flashing, i.e when it gets warm, I turned on hazard lights and these are solid/not flashing as well, does this point to relay.
addo
- x 95
spider
- x 77
I suspect the relay too. I'd change that as its cheaper (even new) than another switch.
Andy.
wirdip
All fixed folks!!!!!! Turned out to be flasher relay, got a pattern one and fitted it today indicators working fine now. Thanks for all the input and a Happy new year.
