Radiator drain tap - C8 2.2 Tdi, 2003
brittleware
I cannot see a usable drain tap on the radiator on our car. There's the expected pipe at bottom near the centre but no means of opening it. Where I'd expect to see one, there's just a hole in the thing - with a little "pip" moulded in at the top. Has someone bodged this? I certainly don't want to buy a new radiator. (When fitting a new temperature sender on Friday I had to resort to draining the system by pulling off the bottom hose!)
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Citroen XM 2.0 turbo
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
oneday
Re: Radiator drain tap - C8 2.2 Tdi, 2003
cant be certain but ive not seen a radiator drain tap for years
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
brittleware
Well, our car has what looks exactly like a drain tap - but it's as if someone has lost the plastic fitting within the tap and bunged a piece of capped off plastic pipe up there! Surely it's a bit over the top to have to disconnect the bottom hose to drain it?oneday wrote:cant be certain but ive not seen a radiator drain tap for years
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
