Bleed Brakes ?
froggy
- (Donor 2026)
- x 4
Bleed Brakes ?
Hi, A couple of weeks ago I replaced rear brake pads , caliper bolts and cleaned up trailing arm and caliper of oxcide build up. The ride is now harder , should I have bleed the brakes on my Xantia? any thoughts, cheers Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 3296
Re: Bleed Brakes ?
I would, as a matter of course, bleed the brakes every time I had done any work on the fluid side of them. Just because you shouldn't get air (or dirt) into the lines doesn't mean you can't.
- x 8421
Re: Bleed Brakes ?
Absolutely yesHell Razor5543 wrote:I would, as a matter of course, bleed the brakes every time I had done any work on the fluid side of them.
