air buble problem fuel pump
ektor
Unread post by ektor »
the pipe between the fuel filter and the fuel pump boch lucas shows air bubble. I have checked all the pipes but they are ok.I think that maybe is the pump that have a problem.in traffic the engine is hot.pls help me. I have a peugeot 206 1.9 diesel. thank you
spider
x 77
Re: air buble problem fuel pump
Unread post by spider »
I would guess the filter housing is the problem, check the seal around the lid / filter.
If there's air in the pipe between, then its likely the filter area or perhaps before that.
Andy.
ektor
I dont think so because the filter is new.Maybe gets air from ( 45 in photo, Air bleed valve.)???
spider
x 77
It could be the pipe between the filter and the pump or likely (42) at fault.
Was the filter / seal good quality ? , a poor pattern one (to be fair I have not seen a poor / bad one) could not seal properly.
Andy.
