I think the rear springs have gone on my Synergie, as the slightest load and the exhaust bangs on the trailing arm and even unloaded, other drivers think my lights are on full beam when they are not. I can't see a break in the springs, but they are very rusty and all the plastic coating has peeled away with quite a bit of metal.
I've bought new shocks and springs to put on, but I don't have a maintenance manual. Has anyone done this before? Is there anything I need to watch out for? Do I need to take all the internal trim off to get to the top of the shock absorber mounting? I asked a garage and they wanted £100 plus to do the job, which seems a bit excessive...they said it was more than 2 hours work, but I would have thought it could be done in less than an hour by a trained person.
Rear shocks and springs replacement
MPV
Synergie XUD9 - the "Duck-billed-clatterbus"
- x 94
Re: Rear shocks and springs replacement
looking on service citroen it looks like a very easy job,
without seeing in the flesh i wouls say unbolt the shockers and the arms will drop dopwn at the back end pivoting on the front mounting bolts,
then the springs lift away as they are just held in place by the length of the shockers stopping the rear of the arms going down past a certain point
Regards, malcolm.
MPV
Thanks for the reply. The bit I'm most worried about getting to is where the shocks bolt onto the body at the top...does this mean taking loads of trim apart to get to the loacking nut?
- x 94
not had the pleasure on a Synergie but on service citroen both top and bottom shocker bolts run horizontally,
so best get under there with a torch and see if you can see the top bolt's/heads
Regards, malcolm.
