Urgent need help
IrfanIbrahim
Urgent need help
Unread post by IrfanIbrahim »
My car wont start unless the gas is stepped. Unconnected stepper motor before to test on high idle problem. Now it wont just start. What should i look first?
1994 Xantia 2.0I
Keep calm & drive a xantia!
Mandrake
x 695
Re: Urgent need help
Unread post by Mandrake »
Reconnect the stepper motor. :wink:
When the throttle butterfly is closed the idle air bypass controlled by the stepper motor is all that will allow the car to run. If the ECU can't operate the idle stepper motor because you've unplugged it it won't start without the throttle being pressed...the ECU opens the idle valve wide during cold starting in particular, then gradually closes it partially a few seconds after starting to bring the revs down.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
