Lexia help please
horsedentist
Lexia help please
Unread post by horsedentist »
I have lexia 436 using it on a C5 MK1 2001.
If I try and access the replacement parts section it says not available on this model like wise fap maintenance is also not available on this model is this normal?
Also I would like to code a radio to replace mine as it is not reading cd's has anyone changed the vin on a second hand radio unit in lexia if so can you talk me through it please.
cheers
Eric
The Birdman
Re: Lexia help please
Unread post by The Birdman »
Check engine ecu for fap ,
go into radio ecu , configuration , change vin number , hit configure , job done .
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
horsedentist
Many thanks for that will give it a go at the weekend.
