air con compresor clutch
dragon
Unread post by dragon »
hi
can i please ask dose anyone know where can i bay clutch for air con compresor?
its for c8 2.2 hdi make sanden model no 1240f
air con still works spot on but clutch on compresor started to make bit of a noise and i got some red dust coming from it
looking over a net i cant find any info on where to get one
dont want to get 2nd hand compresor as it will be coming to end of its life like mine
recon one is £260,then taking pipes off changing seals and re gasing,at any time when you take pipes off dfor air con bit of moist enters pipes
then dryer/resiver gives up
clutch removal tool is about £30 but cant fine clutch anywhere to bay
thank you
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The compressor type is an SD7V16 - you might be confusing people with the 1240F code.
The clutch is a 12V unit, you need the diameter and number of grooves. Non-genuine is easy enough to find usually.
BX
x 19
Re: air con compresor clutch
Unread post by BX »
http://www.mavoyparts.com/storepage823541.aspx
Used this guy a few times. Found him good.
