What I want to know, is what position is "showroom"? Is it towards the centre strip of fuses, or the outer strip?
Vehicle in question an '00 Berlingo but assume the Xantia, Xsara etc would be no different in convention.
Thanks, Adam.
Fuse Panel Shunt - Pre Multiplex PSA
addo
- Sara Watson's Stalker
- x 95
spider
- x 77
Re: Fuse Panel Shunt - Pre Multiplex PSA
I **think** its the outer strip but I'm reluctant to say even that as its been so long I cannot be sure. I'm not even 100% if it was a complete move or just a "one down or one up" with these.
I did not do that many PDI's, I tended to get a lot of repairs like radiators and curious wiring faults (pre-plexed)
Andy.
- x 1044
When they come from the factory the shunt fuse is removed (normally left in the drivers door pocket) & there is a 30 amp fuse in where the shunt fuse normally goes but in a slightly different position. The shunt fuse is slightly wider than a normal fuse so you can't put them in the wrong place.addo wrote:What I want to know, is what position is "showroom"? Is it towards the centre strip of fuses, or the outer strip?
Thanks, Adam.
addo
- x 95
- x 1044
Should add its not actually showroom mode, it's more of a storage mode to stop the battery going flat if the car is sitting in a compound for months.
Showroom mode is a bit different & is more for multiplexed cars, a 'showroom' harness is plugged into the car then configured with Lexia, this allows some of the things that switch off with eco mode to keep working & a trikle charger to be connected so doors can be left open in the showroom to let customers nosey around. I cant say I've ever seen a dealer use the showroom harness though.
addo
- x 95
