Hi
i have a lexia but cant find the key programming procedure, how do i program another remote key to work on a 2005 C4 hdi ? Also if its been used for another car will it reprogram to mine (bought the key off ebay, i intended to swap the original blade into the new case and then reprogram the new circuit board to my car) ?
c4 key programming
oneday
Re: c4 key programming
hi key programming is in bsi cant answer your other questions as im not sure what can be done. you will need your key code number off the card and the bsi code which is 03114 hope this goes some way to helping you
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
johntom
Yes thanks for that, I have the plastic card so I will look in bsi.
- x 3304
If my memory serves me correctly, I have read on this forum that when you are programming keys you need to do them all at the same time. There is something like a query about "number of keys", and then "key1, key2, etc". Best to search the forum.
