Wrong spheres!!!!
cc101
Wrong spheres!!!!
Unread post by cc101 »
Hi all, as previous posts I've been trying to sort the harsh ride out on the Xantia well finally went ti GSF where I bought the spheres from to get some hydroflush. Bought it and just as I was leaving thought I would ask the guy the part numbers for the spheres turned out the guy who sold me the spheres had given me hydractive front spheres instead! Anyway the manager agreed to give me the proper front spheres free. Hopefully this will cure the ride along with the hydraflush.
Does anyone know if any damage would of occurred running hydractive spheres?
Cheers, Chris.
Xantia 1.9 TD 1993 (sinker)
kentc5
Re: Wrong spheres!!!!
Unread post by kentc5 »
I am not sure and someone will correct me here.
I am quite sure .. the only thing that suffers is only the ride.. no harm is done on the system.
Current Cars:
Citroen Xantia 3.0 V6 Exclusive ('98)
Alfa Romeo 166 2.0TS ('03)
Audi A6 C6 2.4 V6 SE ('05)
BMW 735i Individual M-Pack ('00)
Lexus GS300SE Navigator ('98)
Toyota Prius T-Spirit ('04)
Chris570
x 36
Unread post by Chris570 »
no damage at all (other than to your spine) ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The car wil be soooooo soft with ZERO damping... but no issues..
A very sad...
1994 XM 2.1 d auto
Mandrake
x 695
Unread post by Mandrake »
citroenxm wrote:The car wil be soooooo soft with ZERO damping... but no issues..
I'm assuming he was initially given Hydractive strut spheres not regulator spheres... that would give a really firm ride...if it really was two regulator spheres being put on the strut positions that would be VERY dangerous to drive at speed with no damping. :shock:
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
andmcit
x 30
Unread post by andmcit »
I've seen at least another couple of cars with the incorrect spheres fitted after being supplied by GSF
so it's always a good idea to check very carefully the markings printed on them. It's the easiest thing
to mix up when they look identical to the casual eye and the first thing to suspect when replacement
spheres are fitted and don't have an immediate fix to the ride!
Nothing moves you like a Citroën
x 94
Unread post by citronut »
my local GSF supplied 1 C5 type corner sphere for a BX????, i mentioned this a few weeks back in another thread,
and Sir Jim said i would have fun fitting it,
cant remember what thread it was in and did not see if Jim replied,
as far as i Know Andy ( Mothman ) has not attempted to fit it as yet
Regards, malcolm.
x 8444
Hydractive spheres will make it a bit rock-hard Chris. I pleased you've discovered this!
cc101
Hi all, I'm still at my witts end with this hard ride, double checked the ride height with a a tape measure and both front and back are well within tolerance, bounce test is smooth and goes right down at least 4 inches on all corners!
Anyone in the Cardiff or surrounding area fancy giving it a test drive before I end up taking it the Citroen specialist!
Cheers, Chris.
x 8444
So, did the spheres not crack it Chris?
cc101
Doesn't seem to be any better Jim! Possible duff spheres but it does bounce ok though!
Cheers Chris.
Citroenmad
x 110
Unread post by Citroenmad »
How bad is the ride? Better or worse than most conventional cars?
With good spheres it should ride well, even if the LHM is the freshest. You said you have checked ride height, its not a hydractive, and it can be pushed down by 4"s. Are the height correctors free? Its self levelling once you have got in the car?
Im not sure what else to suggest.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
cc101
Only 5 spheres in mine, sinker. Put hydroflush in around 300 miles ago all spheres are new, ride height is within the spec limits, have no idea what else unless the new spheres are shot but I would of thought they wouldn't pass the bounce test if they were shot. Height correctors work fine both turrets were removed and greased.
Would really love to get it riding smooth as it's an early sinker and there's not a great deal of them left now!
Citroenmad
x 110
Hmm, odd. A sinker really should be the softest. Are your spheres definitely correct this time? If they have wrongly sized damper holes or incorrect pressure they will of course give a different ride.
Did you notice any difference at all when swapping from the incorrectly supplied ones to the current ones?
cc101 wrote:Sorry seemed to multiple post!
Just slightly :lol:
03 Seat Arosa 1.0S
cc101
Didn't really notice any difference, maybe the hydroflush has done some work in the 300 miles and has blocked the filters already, wishful thinking will have to check! Apart from that I have tried everything!
Cheers.
