Hi I have a 2.2 hdi C5 facelift There was no power when cold then engine ran fine after a few minuets I changed the airflow meter with an after market one which made the car run worse and threw a few faults in and limp mode I changed the air low meter back but cant clear the faults on my lexia the fault being particulate filter punctured I know this is not the case Can anyone help
Lexia fault erasing
oneday
Re: Lexia fault erasing
hi you have to read the faults before you can erase them. i had the same fault come up at the weekend after i disconnected the maf to clean out the intake pipework
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
chriscdm
Thanks I did read the faults but still cant erase them
oneday
thats wierd is all the intake pipework together and the maf plugged in and the map sensor working
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
The Birdman
Try a BSI reset
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
chriscdm
Thanks problem solved changed air flow meter for a genuine one all codes removed still 2 codes left to clear though engine relay and no radio signal to e c u but car runs fine now
chriscdm
The fault is back and in limp mode (Particulate filter punctured) cant clear code with Lexia can anyone help
horsedentist
Try reading the faults history and fault logs then erase them I had same problem on the BSI but once I read the fault logs and history everything cleared ok.
chriscdm
Ok thanks I read the faults log but not the history will try tomorrow
