Lexia and windows
horsedentist
Lexia and windows
Sorry to ask so many questions but can you reset the automatic window travel parameters using lexia? The passenger door window seems to hit the top of the frame triggering the anti pinch function so it opens back about 33%. even when closing manually if you misjudge the top of the travel it will go clunk and drop back.
DickieG
- Monaco's youngest playboy
- x 33
Re: Lexia and windows
What car is this on?
If its a Xantia I'm pretty sure there isn't the facility in Lexia to do what you're asking, if its a c5 then I think there's a set procedure you need to follow to reset the windows, have you tried looking in the handbook as I think this problem arises after a battery change.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
horsedentist
It is a C5.
According to the hand book if you disconnect the battery for a while the anti pinch is deactivated and the window will only go up a few cm's at a time allowing you to reset the operation. I have tried this and it doesn't work
the anti pinch is still operational and it still closes automatically when you hit the button?
Lexia doesn't show any faults on the window system.
